V27 new layout from template
When creating a new layout from template V27 does not seem to honour the CREATEVIEWPORTS system variable.
I have mine set to off, but I still get the viewport.
This did not occur in V26, so I am assuming it is a regression.
Does it depend on which template is used? I'm not able to reproduce this yet.
No, it happens with all of my templates.
Happening to me too. CREATEVIEWPORTS set to 0. All LISPS turned off. Viewport of random size and orientation created in new sheet "from template". When you delete the view port you cannot enter modelspace in that sheet despite the view port still existing.
This was also reported via support requests, it's forwarded to developers for correction.
Yes, another small regression, as we have come to expect with new releases…
After using the template option of the layout command, you need to call audit, which will remove the wrong viewport ID from the database, then you can safely switch to the new layout.
Otherwise, you will find two mviews in the layout (one misplaced), and deleting it will bring serious trouble.
Same here,
V27.1.06
