v27 dynamic input at cursor issue
When adjusting the position dimensions for BIM inserts, say a window in a wall when I click in the dimensions field to input values the input sometimes resgister in the dynamic input field, to ensure I actually type in the dimensions field I may need to double or sometimes even triple click if for the inputs to register, not sure why its this way but I never experienced this in v26
  • Probably the new dynamic prompt is related to the demonstraited behavior. Could you please try to turn off the DYNPROMPT variable?
