Text being automatically reselected
I have any issue in V26 of BricsCAD Pro that has been occurring since I've started using it.
I select a text entity and edit the text, then press enter to confirm the changes. I then press enter again to exit the edit command. Then if I select a different text entity, bricscad selects the new entity plus the last text entity I selected. What happens is that I end up moving random text entities to various areas of the model space if I forget to deselect that last entity. I've attached a video of what is occurring, I'm thinking this is some sort of setting I need to adjust.
This is a known problem in V26: text selection is kept after DDEDIT command is finished, thought text is not highlighted. Please use Escape to remove this selection before other command execution. The problem is corrected in V27.
