Startup
I have loaded version 26, but when I start BricsCAD, it reaches the startup screen and then freezes. To exit, I need to use Task Manager to end the task. Any reason why this happens?
Are you running 3rd party tools? If so, have you checked they are compatible with the version you're running? Some plugins, such as 12D Synergy may have not yet released an update to support releases newer than V25.
To check you could try starting BricsCAD in safe mode, which disables all 3rd party apps.
If it runs, then it points to a 3rd party tool being at fault.
CAD Concepts Ltd
