How to add partial CUI custom ribbon panel to 2D Home ribbon tab
I have just updated to v27 so trying to figure out how to transfer customisations instead of reinventing the wheel each time.
In v25 I have created a partial CUI file containing my custom toolbox/tools, and ribbon panel.
When I load the partial CUI file in v27 I can see the contents listed but cannot add the custom panel to the Bricscad 2D Home tab. If I try to drag and drop it shows a "no-entry" sign, and when I RMB > "Append panel" my custom panel is not listed for selection.
Can anyone explain how this is supposed to work?
  • Unfortunatley when Ribbons were introduced they abandoned the MNU text file source and went to a cui/cuix which are multiple XML files. Often looked at making CUI files say using Excel/Cad rather than the CUI editor.
    Back to your problem in old method you would do a "Menuload" and add your custom menu to the current workspace. So if you have exported the custom ribbon try menuload.
