XREFLAYER setting does not work on inserts as external reference
When using ATTACH the XREFLAYER setting works fine, attached blocks will be put on the assigned layer.
When using INSERT and select insert external reference the XREFLAYER setting seems to be ignored or not recognizing the inserted object as an xref, the result is that the block will be inserted into the active layer instead of the layer specified in XREFLAYER.
The interesting thing is that a LISP that moves xrefs to the layer specified in XREFLAYER will move both objects to that layer, even after putting both on a different layer first. Why is the XREFLAYER not working on xrefs from INSERT with the external reference checkbox ticked? I would assume an xref is an xref, or are there different kinds of xref? The documentation does not seem to specify any differences, only that the XREFLAYER is not specifically mentioned with INSERT, just with ATTACH.
Is this as designed or a bug?
