Form Components from blocks
I have a 3D model that contains many of the same shape and size bracing cleats. I "blockify" the model and I get all the similar cleats changed to blocks.
I make one of the blocks an external component using "bmform" and giving it a unique name.
My question is, how do I have this external component replace all instances of the blocks that were created with the blockify command without have to insert the component individually and locate it in the model to suit?
thx Ian
