Project ARC Bridge: Which Trees Need to Transfer
I have question : I am learning bricsCAD, I got the project of ARC bridge in valley. There are too many trees. I want to Find out the which trees I should ask to cut for the ARC bridge project. So I got the bridge plan and trees point cloud. I have made tin surface from trees point cloud and then I am plannning to create 3D polyline from the area of bridge and converting to tinsurface. Then using TIN Volume Surface tool I will tell which area of trees neeed to cut and when I will have the exact georeference point of trees I can tell which exact trees need to transfer. Is it right.?
