3D extrude to solid
This is not a high priority .. at least for me :-)Scenario 1 = WORKS !1) create a cube using the "BOX" command, 2) create an interfering sphere with "SPHERE" 3) "SUBTRACT" the sphere from the cubeScenario 2 = FAILS !1) create a cube by "EXTRUDING" a rectangle 2) same as sch.1 3) same as sch.1Without going into details extruded solids just don't participate with solid editing.
  • I can verify this behavior. It is a drawback for any real work with solids. Fix soon!
  • we're working on this issue. We have an update ready which will be released. 3d extrude will be fixed in the first update after that.regards, sander,bricscad
