Solid Edit Problem
If I draw several solid boxes, only in the first one I am able to do a face selection. I tried to extrude a face in the first object, it works fine, but after that all other objects simple don't have their faces selected and consequently I can't edit them.
  • We could reproduce this and fixed it in the coming update. Face selection was successful if you selected an edge(eg, an edge on the back side of a solid), but not when you clicked in the 'empty' part of the face. regards, sander, bricscad
