More v. 4.0.0029 bugs
Icad 4.0.0029 doesn't allow the user to select a file name or location when plotting to a file in Windows XP Pro. It sends the files to a default location and name. This makes it just about impossible to deal with when making multiple plot files. -Icad asks to install new menu and toobars each time it is started until you agree to allow it to. I don't want the new menu and toolbars I want my familiar old customized ones!
If IntelliCAD is sending plot files to a default location you need to switch off the "Generate PRN files automatically" option in the SPOOLING SETTINGS. Choose PRINT SETUP > SPOOLING to access the spooling settings. These settings allow you to control the 'print to file' output.
