DIMTEDIT
Have anybody encounter with the DIMTEDIT problem in ver.2.2.0019. When I tried to move the dimension a side the hole dimension disappear. The only remaining thing is the dimension line. When I exploded the line the dimension text was so small isdoesnÂt even have a scale to it.And thanks to Shawn Niles for the help with licenses problem.Regards,TAZH
Yes I have had that problem before in .0016. Also when sometimes I get about 20 copies of the text making vertical copies of themselves. I am not sure when this came up. Maybe when I was macking around with DIMTVP and DIM > UPDATE commands.
I downloaded ver.2.20025 the DIMTEDIT problem is still there.
I had that problem in .0019 however when i downloaded .0025 I uninstalled Icad and deleted the directory. Then installed .0025 and apparently the problem is gone. I reset the dimvars in my Icad start up dwg. If I run into any more problems I'll let you know.
