Trimming polylines
Using 2.2.0025 and PLINETYPE is set to <2>; I joined a set of lines going from left to right and another set offset from the other and joined them going from right to left. I had a line crossing the right ends of these two plines and trimmed the right ends at this line. The first pline trimmed OK but the second one appeared as if nothing happened. But on further review, the pline was trimmed alright but the original pline was duplicated and placed over the top of the new line. You can delete this duplicate. But it is a hassle. Does this problem have to do with PLINETYPE being set to <2>?
The problem is already corrected in the latest bèta version and will be available in the next commercial release which is planned by the end of june.
