OSNAP bug while printing
I just found a strange bug - follow these steps:Print dialog/Select print area/... will snap to endpoint etc. as expected. Print the selected part of drawing. Now, again Print dialog/Select print area/... will NOT snap to endpoint etc. But if you pan/zoom before clicking on a corner of the area to be printed, OSNAP works again (but will not work in the next print dialog if you don't pan/zoom). Not a critical error but seems to indicate some disorder. Ver.4.0.0029
