DIMVARS
What does DIMSS and DIMSSPOS control? What are the optional settings for ICAD and for when a R14/R2000 drawing is brought in???Thanks.
  • I did not know this variable. Remarkably, it does not exist in Acad and is not documented in Icad.The code indicates it's for use of superscripting in dimensions. You can see the behaviour in the dimsetttings dialog under the text tab:There's a checkbox to apply superscript to numbers after the decimal separator,And a number to indicate after how many decimals this should be done.regards, sanderbricsnet
  • Sander,What? You're a Bricsnet associate. How could you not know about this variabble????? What else don't you know about the software? How can we the end users work with software that has unknowns? Is this the reason for the bugs???? Also, what about all of those system variables that are noted as not implemented by ICAD? Are they working now and the help just hasn't been updated???? These are some VERY SERIOUS questions that need immediate responses. Paul Sullivan
  • You pick the wrong issues to get upset about Paul.You asked me about two system variables that are not documented in the helpfile even if they have been around a long time (before Bricsnet started doing intellicad).The helpfile is not complete. This means it took me a few minutes longer to find out what these variables were. I did not have to ask anyone who worked on that part of the code or start digging through any archives.There is not enough material there to start working your way up to a thundering climax.regards, sanderbricsnet
