draw order do not saved
1) i have solid-hatched a rectangle.2) i have edited the order of it so the outline will be showen.3) i have saved the draw and re open it.4) the new draw order was not saved.is there a way to save the new draw order?
Since the most recent entity lies on top you can use the following workaround.1. Select the entity you want to put on top.2. Press Ctrl X to cut the entity from the drawing3. Press Ctrl V to paste the entity in the drawing again.Now the pasted entity is most recent entity in the drawing and therefore will not be covered by any other entity.
