creating solids
Hello,I have a complex shape drawn 2 dimensionally and would like to extrude it into a solid lineal form so i can slice the ends in order to put a mitre on my extruded member.Is this possible?cant seem to get anywhere with the help provided with bricscad.thanks in advance,Jeff Halll
Ver 4.0.0029 - Not possible Yet. You can extrude your 2d into a solid but that's it. You can't edit the resulting solid. I believe they are aware & working on this issue. There's hope in the next release.Dez
Actually it is possible.I have converted all the lines in my complex 2d shape into polylines, joined them, and now I can extrude the shape into a 3d solid and perform slices and other functions on the shape.Thanks jdhhall
