Snaperror V4
I have noticed that since introduction of V4 the Perpendicular snap only works on its own.You have to turn all other snaps off.Slightly irritatingPatrik
  • I have found this to be the case sometimes. If you try to snap to perpendicular to a long line away from the end (or a long curve) you will get the perpendicular rather than the end point. End point snap has nearly always been the dominant snap.On the positive side, I like the new "copy from" entity function for text. It now copies not only the text layer and color, but also size and orientation.
