Menu Import
When importing an icm menu, I expected it to replace the existing one, but instead, it adds to it. So before importing, I have to manually delete all the items first. Is this intentional? This is probably useful if I could export selected menu items.
There is an option to "Append to existing menu" in the import dialog box, which should be unchecked.
Ya. Funny I did'nt notice it after clicking back & forth the dialogue boxes so many times. Perhaps I just expect to see the option on the last dialogue box... Thanks for the reply.
Is there an easy way to create the icons for menu toolbars?
Use Tool_Customise & select Toolbar Tab. Drag desired icons to menu area. Click the new icon and in the same dialogue box you can change the associated command, tooltip etc. Click Option and you can change the icon graphic by selecting a built in one or a BMP file.
