CHAMFER problem
Another strange thing, this time with CHAMFER (see http://www.pontex.cz/download/icad/chamferproblem.dwg). The two yellow lines to be CHAMFERed with dist1=dist2=0. Depending on the position where one clicks in the CHAMFER command, the result differs. Fillet works consistently as expected.It's not a priority error but it could attract some interest of developers debugging the 2D core functions.Tested to occurr in 4.0.xxxx and 4.1.0006. Can you confirm the error or is it something that happens only at our site?RegardsVaclav
