Error - Rotate By Reference
Another error in the 2D core functions: Rotating by reference gives wrong results if angles are set to be measured clockwise. To see a demonstration of the error, see www.pontex.cz/download/icad/RotateByRefError.zip Regards,Vaclav
  • We fixed many problems with clockwise rotation and rotated base angle(ANGBASE and ANGDIR) this year. Indeed, this one is still present.Thanks for reporting itregards, sander
  • Tested the problem on 4.1.0016. It was NOT corrected.RegardsVaclav
