Server problems?
This is basically a test message to see if the forum is working or not. At the top of the page I always get a "500 Internal Server Error","java.lang.NoSuchMethodError at boa.CorporateTemplate.writeTopNavigation(CorporateTemplate.java:324)"RegardsVaclav
We have moved our site to a newer server. This error occurs when you connect to the old server. Please make sure you use www.bricscad.com and not an IP address in your bookmarks.Jurgen
Yes, the problem was in the outdated bookmard in my browser. Thanks for your reply.To make sure everything's running fine, please note the following:- I have posted a message on the forum called "ICAD ghosts" some time ago- PetrMat replied today, so I received his reply via email- In the email, the address of the forum is still "Click below to jump to the forum http://62.72.108.142/jive/thread.jsp?forum=2&thread=1880"Shouldn't it point to the new address as well?RegardsVaclav
