Error in Dim Continue, local coordinate system
Again, a 2D functionality problem:DIM CONTINUE is unusable if the current coordinate system is not parallel to the global C.S. To see a demonstration of the error, download www.pontex.cz/download/icad/DimContinueProblem.zip Regards,Vaclav
  • I've had the same problem. When I used a horizontal or vertical dimension when the UCS was rotated and then tried to continue the dimension, the dimensionline continued horizontal or vertical using the world C.S.Using the aligned dimension, the dim continue worked fine.RegardsJos Bex
  • The error still exists in 4.1.0016. Very bad.Regards,Vaclav
