clipped images (realtopo program)
I use realtopo for acad14 on ACAD14 and am trying to read the files using intellicad2000. The raster images can be seen, but are not clipped as they were in Autocad. The program uses clipped images to seamlessly join usgs topo tiff files together. Does intellicad support clipped images?
The Raster Image facilities cannot (yet) clip images. If you need clipping to join different images you must do this in a separate program (e.g. Paint Shop Pro, Photo Shop, ...) and insert the result in IntelliCAD.
