Hatch & Print problems on ver 4
1) mouse right button seems to be not working. used to in ver #3. 2) point styled hatch is not beeing printed on the same printer that it was printing fine on ver #3.3) Print settings are not being saved like they used to on ver #3. i need to re set for each draw.thanX
points 1 and 3 are due to a registry problem. The windows registry structure for IntelliCAD has changed over time, and there have been some reports of problems when the user switches between old and new. Point 2 , I don't know yet. It could also be due to the transition. Leading to wrong pen map settings. Please check by cleaning the IntelliCAD user settings of the registry. (i sent a small file that does this)regards, sander, BricsCad
