4.1.0009PRO-polyline bugs
In ICAD 4.1.0009Pro new bugs appeared when working with polylines:Scenario A1. Draw a polyline2. Invoke PEDIT and click on the polyline3. Type "W"(width) and enter a positive number, e.g. 1; the width changes - so fas, so good; exit PEDIT4. Invoke PEDIT and click on the polyline again5. Type "W"(width) and enter a differen number, e.g. 0; NOTHING HAPPENS => bugScenario B1. Draw a polyline2. Invoke PEDIT and click on the polyline3. Type "F"(fit) or "S"(spline); ICAD returns error "Unable to fit a curve to the selected polyline"These problems do not occurr at 4.0.0041CZ version.Any suggestions? Can you reproduce this?Regards,Vaclav
  • These bugs were fixed in build 4.1.0014, which enters Beta testing today. As this build contains only minimal differences with regards to previous builds that already have been beta tested, we plan to release it shortly, that is, if no stopper problems occur.Best regards and thanks for reporting the problem.
  • Tested the problem on 4.1.0016. It WAS corrected. THANKSVaclav
  • I have the 4.1.0019 pro - and this problem still happens!!Thanks in advanced..Sasha
  • The two procedures described above work. One problem we fixed with polylines was that some operations require classic polylines (for example, fitting) and IntelliCAD has to convert lightweight polylines implicitly to classic polyline. If this step was omitted, fitting could not work.please send a drawing and a procedure so we can see what you mean exactly by 'this problem'. sander
