Using STRETCH command for dimensions
STRETCH command acts exactly as a MOVE command when is applied on Dimensions. As normally we use the object corners directly as a reference points for dimensioning - this is very dangerous - you stretch the object, but MOVE the dimension. Any chance to have it fixed? Regards Petr
