Using STRETCH command for dimensions
STRETCH command acts exactly as a MOVE command when is applied on Dimensions. As normally we use the object corners directly as a reference points for dimensioning - this is very dangerous - you stretch the object, but MOVE the dimension. Any chance to have it fixed? Regards Petr
Sorry for posting this twice. Some Java error message had occured during first posting, so I reposted it. But despite of the message both postings proved to be succesfull. Petr
They stretch fine on my machineW98 - BricsCAD V4.1009
This feature is unfortunatelly occasional. Sometimes it works fine, sometimes wrong. I can recall the misbehaviour quickly in very simple dwg - it occurs normally within, say, second to fifth stretch of the dimension - sometimes even with first one. Simple example is on www.pontex.cz/download/icad/stretchdimerror.zip - also with the script. Regards Petr
