ICAD / XP Pro - wont accept my license key
I've recently tried to install an ICAD 4.1 upgrade on an XP Pro. I've tried using 3 different Liense Keys but I get rejected each time. Even after uninstalling existing ICAD from my machine I still cannot get any License Keys to be accepted. I was told there was a patch that can erase the registry data so ICAD can be installed on a "clean slate". Can you please send me this patch.
  • Could you please send us the keys , so we can check if they are (still) valid? The fact that the licensemanager rejects your key suggests that the problem is with the key, not with the installation of IntelliCAD. Maybe there is more to it but let's start by checking the keys.kind regards,Alexander Van Heuverzwyn, BricsCad
