Print settings
Minor (trivial) bug (try this in Print dialog):- Check the "Print only area within specified window" (which I think should be default)- Go to Print setup; there, click OK or Cancel to go back- The check is gone; If you don't check it again, your print can be quite different from what you wantedRegardsVaclav
