Paperspace printing
Hello,In the past, I have printed using paperspace views with separate drawings inserted as x-refs, such that the linescale (ltscale ?) for each drawing was set separately, How can I do that, or where in the User Manual can I find how to do that?Thank you.VM
  • The variable psltscale controls the display of ltscale, e.g. if you want the ltscale of an xref'd entity to take precedence over the paperspace ltscale, you should turn psltscale off.Intellicad help files are outdated for this variable.
  • Thank you. I'm getting this to work again!
