printing problems
The print dialog "print area" setting is stuck in "Current View". If I change to "window" then go to "print preview" it reverts back to "Current View". I haven't had this problme before, it just suddenly started happening. Anybody know of a setting that could be causing this behavior?
  • The problem only happens in model space.
  • Problem appears resolved. The "Use settings from" field on the print dialog had somehow been changed to "current layout" rather than "previous plot". Changing it to "previous plot" seems to have fixed the problem. I hope!
