Menu path names disappear in V4.1.0019
This is a problem related to the following installation:Bricscad Intellicad Classic V4.1.0019 on Windows 2000 with SP4.I am using customised menus and part of this customised menu has image menus. I define these paths for:-Blocks-Slides-Lisp-MNU filesThese paths are defined in the Menu section. In addition I repeat the path for BLOCKS in the blocks section.The paths I define here should be retained in subsequent sessions for the same user. However they disappear in some installations and are retained in some others.Why should there be such inconsistency?
We don't know how this happens. The settings should be retained. If the settings are lost, at this stage we can only guess. These hypothesises come to mind - a first possibility you use different profiles and while the settings are saved in one profile , they are not available in other profiles. This is as designed.- a second possibility is that IntelliCAD confuses profiles of version 3 with version 4. In that case, IntelliCAD saves settings in a version 3 profile and reads them from level 4. The new profile structure is a level deeper in the registry than the old profile structure. In that case you would need to remove the level 3 profile.regards , sander, Bricscad
