True Type Text Fit
I am using version 4.1.0019. When using a True Type font and fitting a long line of text between two points, the end of the text always runs past the second point. It doesn't happen with short lines of text - only long lines - 20 to 30 characters or more.
Can you send a drawing to clarify what you mean?With plain text and option 'fit' the text should always fit inside the endpoints. Mtext does not have a 'fit' option, The endpoints affect the text only because they cause the text to wrap to the next line. But the text can easily extend beyond the right endpointregards, sander , bricscad
I've uploaded a file to Bricscad Support demonstrating this bug. The text fit feature works fine with the .shx fonts, but not with .ttf fonts. Will there be a solution?
