hatch crash
Since upgrading to version 4.1.0033 I cannot use thehatch command without ICAD crashing. I tried differentdrawings and it still occurs. The error states "invalidpage fault in kernel32.dll". The operation I'm trying to dois hatch an area enclosed by an arc if that is revelant.Would appreciate any/all suggestions.
  • Version 4.1.0036 has been released to fix problems with bhatch. Probably you want to give it a try.
