hatch crashes
I am experiencing problems with the hatch command crashing the program. This is not the bhatch command but direct hatching with lines as the pattern. It only occurs when crosshactch area is selected as an option. I have upgraded to V 4.1.0036 and am still having this problem.
  • Thanks for your valuable feedback. We are searching for what is causing problems with hatching, but till now could not reproduce it on our side. Your description is definitely helpful to point us in the right direction. If you have further details or a reproducible case with a sample drawing, that would be very welcome.We are working on this with priority.
  • Thanks again for pointing us in the right direction: we managed to find and fix what went wrong.End of next week we plan to release a new build that includes this fix.
  • Where do I access this V4 build?
  • Martin,how unfortunate your email address in our customer base was obsolete: Friday I immediately responded to your support request and returned a recovered version of your drawing so you could continue to work on it over the weekend. Sad to see the bounced mails in my mailbox this morning... I will forward them as yet to the mail address you filled in on the forum now.Regards,Hans De Backer
  • Great response, thanks! I appreciate your responsiveness. 'sorry about the outdated e-mail address! I'm still wondering though if I might locate the final build of version 4 somewhere to address this hatch problem?Thanks!
