Alias for _XRM
The _XRM is not found in the Customize/Alias, how then to assign a new key to execute the Xref Manager besides type the full XRM or from the Insert pulldown menu?
If you export your current aliases to a file, you may edit one of the aliases in it to point to XRM. Then reimport the file (remember to uncheck the "Append" option when you import)
