VBA Snapping
I realize that in order to retrieve snap coords form within VBA program you must use .Utility.EntitySnap method. I found that the OSmode does not return the vertex of solids. Since ICAD supports snapping to vertices of solids I thought that this would be the case in VBA also.Is there any work-arounds, if not does it work in LISP, and could a LISP routine be called - returning the Point info.
Howdy, Stranger!
