Erroneous Snap in 4.1.0040
When permanent endp snap is set, picking anywhere inside a closed polyline with a non-continuous linetype will pull any pick to one of the corners, even off-screen.With flyover snapping on it doesn't happen.Never noticed this in earlier versions, but it may just be I never struck those circumstances.
  • John,thanks for pointing this out, we could indeed reproduce this erronuous behaviour. We will lookup the cause and fix this.Kind regards,Hans De Backer
  • I consider it an extremely minor fault in a most excellent program.
