How to restore menus to original?
I was trying to import my MNS (the compiled menu file) from AutoCAD. However, the results are quite messy with very long pull-down menu names that span multiple rows. The icons for tool bars are missing many of the images. I'm trying to restore it to the original install condition. I've uninstalled and reinstalled BricsCAD three times now. When I realized it was not successfully deleting the BricsCAD directory, I did that manually, but my messed-up menu file is hiding somewhere and evading both the uninstaller and my own efforts to delete it. How do I put things back ? (Of course, the next question will be for guidance about adding my custom AutoCAD toolbars)
Please have a look at the following knowledge base articles that discuss restoring of menus. You can find more on menus by doing a search on 'menu'http://www.bricsys.com/common/knowledge/topic.jsp?id=60http://www.bricsys.com/common/knowledge/topic.jsp?id=104Best regards,Hans De Backer
This was the info I needed to keep working today. I can also more confidently try other ways to import my AutoCAD menus, knowing I can fix any problems. The challenge with using the knowledge base is that you must first know what words to search for, and then avoid using words that will give you a hundred pages. Your personal reply was greatly appreciated.
