problems
Hello,I've come across these questions. Thanks for any answers:Is there a quick way to delete layouts? (wihtout having to type its name...)Dimension leader's don't display if the text has been moved, even if slightly. (by the way, can we shorten the lenght of the leaders, for me they're too long)?'Send to back' does not retain its settings after closing and re-openning the file. Is this normal?Nunofrom Portugal
    1. Delete layout without typing it's name:in the last quarter of 2004 we will release a BricsCad V5 update that supports layout tabs. This will allow to rightclick a tab and select 'Delete' from the pop-up menu.2. Dimension leaders:Could you please enter a support request for this problem and provide details about the dimension type used, the dimension style, etc., or better: add a sample drawing. We tried to reproduce this but did not yet succeed: dimensions have tons of settings that could influence this.3. Draworder is indeed not yet stored in the drawing. This will also become available during the 4th quarter of 2004.Best regards,Hans
