ADT proxy objects
I notice that the ITC has beta code for ADT proxy objects. Does BricsCad plan to add the capability to work with ADT objects? The biggest issue I have with changing to Intellicad is that many of my clients use ADT, and in Intellicad I can't even see that the proxy objects exist. The minimum function I need is to be able to see the ADT objects and explode them to line work. Even better if there was the capability to clean up ADT drawings similar to the "Export to AutoCAD" function in ADT. The specific issue here is wall intersections, which can take hours to clean up manually on a large job.
Support for ADT proxy objects is planned for the second quarter of 2005. Best regards,Hans De Backer
