Crash when inserting complex block
I have a hair-shredding problem here. I have a model of a site, and I want to insert multiple instances of a model of a housetype into it. Both created using same version of BricsCAD (5.0.0020) and Architecturals (4.1.0001). If I insert as XREFs, it works fine. However to export to my rendering software (ArtLantis) I need them actually in the drawing. If I try to bind the XREFs, everything crashes. If I remove the XREFs and try to insert the housetype model as a block, everything crashes. I've tried all the usual suspects, such as closing multiple windows, making sure it's inserting onto a dedicated layer, etc, but no can do. If I reverse the process and insert the model of the site into the model of the housetype it works fine, but this is less satisfactory. Any ideas?Many thanksPhil B
Phil,BricsCad V5.0.0023 includes a fix for a problem with the dxf70 bit of layers of Xref files that was not correctly set during attachment. Though we did not ourselves experience that this led to crashes, it looks worthwhile to download this build and give it a try.If the problem persists, please enter it as a support request and attach the files (as a zip file). We will investigate what goes wrong and help you out asap.Best regards,Hans
