Ver 5.1 crashes
I was thrilled with the new version, that from day to day it gets better and better. But to my disapointment, I had to go back to the previous version. It crahes the moment I try to plot. Error displays "Out of memory". Even in an empty drawing, trying to change configuration of pens and ploters, it Gives the same error mesage. If you persist, then it announces "Error in Kernel..." and you have to boot the computer.People were cpmplaining about the command "UNDO". I did not see any notification about solving this problem in the new version either.
Further inspection reviled that the error "OUT OF MEMORY" is displayed only when choosing A PLOTER like HP650 or HP1050 rather then smaller printers. This is true for operating system Windows Millenium. I could not produce this error under Widows XP.
It crashes even when giving the page setup command or a print command on Windows XP. I haven't yet tested on other windows yet.It crashed in Dview command and save commands also.Undo is a very serious problem and nothing has been mentioned inspite of so many people reporting the problem. Just cosmetic changes do not help.
