export to bmp
I'm trying to export part of a drawing to BMP but I seem not to be able to select the area to export. How can I do this?nuno
Create a new layout in paperspace with an mview of the area you want to export. Then use BMPOUT for a quick export or File-Export to BMP to set a size. Caution: both of these export the drawing with a border around the mview (in other words - what you see.)
