Kernel error
Again there is a glitch in the new version 5.1.0013 . Under Window Millenium, when you exit, you get the message: "ICAD has caused error in KERNEL32.DLLICAD will now close.IF you continue to experiance problems, try restarting your computer" Fortunately, it gave you the chance tosave your work. Regardless of the advice, be sure tha even if you boot your computer again, you are sure to get the same message agin. I could not reproduce this error under Windows XP.
