Wblocking and Coordinate systems
Just to make everyone aware... At least for those who care about coordinate systems... If you wblock items out of a drawing using 0,0 as the base point, the block that you create will not be on the same coordinate system as the original.I have submitted a support request for it already.Just wanted to make every aware of it just in case you send items to other people using the wblock command and have 0,0 as the insertion point.If you use the copy command, instead of the wblock command, and select the items you wish to export and use 0,0 as the base then inside of a new drawing paste it at 0,0 and save it, it will be in the same coordinate system as the original.James
  • Sorry forgot to say that this was happening with version 5.2.0006
  • You are so right. I think that this one is a very serious bug, because WBLOCK is a frequent used command. I think that they have to take down this version and make serious check.
  • This issue has been fixed in version 5-2-0010 which has been released.
