CopyObjects
When I found the CopyObjects function in AutoCAD type library I was really happy because it saved me for a few thousand lines of code.Do I really have to write this method myself, or are will this method become available soon?
  • This is indeed a monster function... and you have a point that it would be a big help if it were available in the BricsCad V5 COM API.I have asked a developer to estimate the task. Depending on the outcome we can see where we can fit it into the development schedule, which is, surprise, quite loaded already...But the least we can do is give it a try.Best regards,Hans
  • Thanks, Hans. I felt a bit frustrated when I realized I had to do all that work, but I'm more than willing to do a bit of work if I can port my application to a CAD platform that everyone can afford.
