3D block insertion problem
I made some wblock from many 3D objects. When I insert those objects I get a different insertion point that the one I had specified previously. For example I draw a box with the insertion point 0,0,0, when I insert that box in a new drawing at the 0,0,0 coordinates the box is positioned at different location. Sometimes it seems that even with the option Position block when inserting is checked, it takes in account the insertion point coordinates that are greyed.
  • We tried to reproduce this problem but didn't succeed (yet). Could you please enter this as a support request and add some sample data to illustrate the problem? Please also specify exactly which commands and options we should use to trigger the problem.Best regards,Hans De Backer
