3D
Does anyone know how to transfer 3d solid entities to Blender3D?Thanks for any ideas.nuno
yes, I must work, I hav't time write this subject next time long textYou looking for in View Properties in Blender and scale spacing and lines - Problem is in Blender scale - 1:1000 by pssometimes Bricscad bad export dxf but if you clear drawing may by is OK
command : "3dconvert" - ACIS to polyline Blnder
The problem is that, as far as I experienced, 3dconvert makes a real mess out of a complex solid. I tried with a normal building elevation with 6 windows, some curves and slants, and with 3dconvert I got mesh faces covering the holes in a confusing way.How can I improve this?thanks
